What tool tool did you use to remove the radio?
Old 03-19-2009 | 04:08 PM
RextheJeep's Avatar
Default What tool tool did you use to remove the radio?
I want to install my mic mount behind the radio and cannot find a tool to remove the screws? I have tried every tool I have and canot find one that fits the screw head. What tool have you guys and gals been using to remove the screws? I can remove the dash center panel and the bottom panel but when I get to the screws I cannot get them out!
Old 03-19-2009 | 05:03 PM
jpp's Avatar
jpp
Should be a 10mm socket or a Torx T-15
Old 03-19-2009 | 05:25 PM
RextheJeep's Avatar
My 10mm socket is too big? What is a Torx T-15? is it a wrench? or a screw driver? Shouldn't I be able to get one at Lowes or Home Depot?
Old 03-19-2009 | 05:47 PM
AK4Dave's Avatar
It's a driver. A torx is like a star, or an *astric*.........kinda like a doubled up phillips head. You'll recognize it as soon as you see one. As yes, you can get them at either place.
Old 03-19-2009 | 06:06 PM
JackMac4's Avatar
Its actually a 7mm socket. I have a 1/4 drive flex driver that works perfect..
sears.com/shc/s/p_10153_12605_00904355000P
I've taken my dash apart about 10 times and it works like a charm every time.
Old 03-19-2009 | 06:57 PM
tolh13's Avatar
x2. super easy
Old 03-20-2009 | 01:31 AM
RextheJeep's Avatar
Thanks ! I will get one tonight and try it!
Old 03-20-2009 | 03:10 AM
nosmr2's Avatar
There's a video out there of some guy pulling his radio out in about 30 seconds. Maybe someone still has the link.
Its the easiest stereo I have ever removed.
Old 03-20-2009 | 06:06 AM
racerx's Avatar
x3
yep, check out the link in the second post.
https://www.jk-forum.com/forums/jk-electrical-lighting-sound-systems-13/how-do-i-remove-upper-dash-piece-58988/
Old 03-21-2009 | 06:33 AM
RextheJeep's Avatar
The 7 mm socket worked! Thanks everyone!
Quick Reply: What tool tool did you use to remove the radio?
