What is this female socket?
Can anyone tell me what this female socket is in the rear driver brake light compartment? My JK is a 2008 and I have removed the brake light housing to change bulbs many times over the years, but never noticed this extra socket.
Sixty4x4 (06-08-2023)
Do you have a hard or soft top? I have a 2011 JK Sahara with a soft top and there is an unused connector above my driver side taillight, but it is in the interior. Mine is for a hard top's washer/wipers and rear defrost, although my connector is inside in the rear left corner, right above taillight. That would be my guess. You could confirm by reading each terminal for voltage while turning on the rear wipers switch. Since everything is wired using a can bus system, the signal wire (input coming from wiper switch) will only read 5 volts. Power wire should read 12.
Thats one side of it, the other side plugs in somewhere around the tail lights, im almost positive its that. What else would it be? I have aftermarket 3rd brake light/license plate light. The only thing unplugged on mine is that same cable, i never tow and my harness got messed up so i unplugged it. I did all the wiring myself so i think that is the only option??
user 729872082 (06-15-2023)
