WARNING rubicon owners!! Your swaybar will get you!!
Old 07-11-2013 | 11:53 AM
  #31
AFCrawler's Avatar
Have they fixed this in the 2012 or 2013 JK's?
Old 07-11-2013 | 12:38 PM
  #32
MontaukRubi's Avatar
Any pics of this time-bomb?
Old 07-11-2013 | 03:01 PM
  #33
dstock's Avatar
I think the real question is how many people have actually had this problem where they have been stranded by their swaybar motor malfunctioning?
Old 07-11-2013 | 06:15 PM
  #34
DonP's Avatar
"Chrysler engineered to be great cars" not so much jeeps
Old 07-11-2013 | 06:16 PM
  #35
DonP's Avatar
Or trucks or cars now that I think about it
Old 07-11-2013 | 06:37 PM
  #36
Rubichronic's Avatar
My e-disco failed at around 55,000km. Although I didn't have the same consequences or failures, just the flashing light. Had it replaced under warranty. It still works, but I have just added quick connects and will probly start using those on the more flexy trails, and just the e-disco on easy stuff. Even connected, the e-disco can still limit travel a little, especially in a lifted jeep. It's a cool feature, but in the end not reliable and not necessary.
Old 07-12-2013 | 05:25 AM
  #37
NativeMsSon's Avatar
I have read through the thread and have a question. If you are in the middle of no where and the e-disco fails on you, what is the best / only thing to do to get the jeep back to going? Unplug it, lift battery cable for a period of time to try and reset TIPM? Just want to get a handle on how to take care of this if/when it happens and I am away from home. Thanks
Old 07-12-2013 | 05:51 AM
  #38
20jk08's Avatar
Default re:
Unplug the connector, ( which the dealership did after the outrageous quote for repairs), I drove around with it unplugged, bagged, and tied up out of the way for a couple weeks till I replaced the motor with the evo manual disconnect.
Old 07-13-2013 | 09:30 AM
  #39
Marmot mb's Avatar
E disco is a ticking time bomb. Either that it will fail and not re connect ( dangerous if you make a hard emergency turn). Or that if wires fry short it effects the entire can bus and computer system. Many have reported fried TIPM modules from shorting E disco connector.
Mine shorted caused entire dash to go bonkers, luckily i unplugged it and no TIPM damage. Bagged connector. Bagged motor so far so good but dash light flashes. A procal unit could resolve this though.
My advice if you are not just a city mall crawler is to plan to replace it with a non edisco sway bar and purchase one of the many cheap and great options from after market. Oem sway bar when disconnected i believe will give greater flex.
Evo makes a $80 knob to add to your e disco motor that works well and allows you to manually actuate the OEM motor however.... If the motor seizes or fails to operate again you are screwed and cant engage the sway bar.
Good idea in theory for e disco horrid way over engineered piece of crap in reality.
Old 07-16-2013 | 05:31 AM
  #40
Thanks for the info. I plan on doing some water proofing on it when I get home to try and help prevent problems. Will be looking into my options for down the road.
