Warn winch just clicking
Well I recently ordered and installed 2 new solenoids bc my warn 8k lb winch was just clicking. Didn't matter wether I was going in or out with the cable. Well that didn't fix it. 99%sure it's hooked up right. What else could it be or can I try to diagnose the problem?? Here is a pic of it for reference.
Start flipping the wires around on it. I got a used warn xd9000i with no instructions so I just connected the wires in a trial and error method and it did the clicking thing too, eventually I got it right and it worked great
Wires coming in from the remote plug in or the 3 wires coming in from the motor to the solenoids?
Motor test procedure here:
http://www.youtube.com/watch?v=pxKrseTT1a4 If you can't get it to turn it is probable the brushes. At only 12Volts, any little corrosion or particles on the brushes or commutator will stop current flow. You might try cleaning them. Similar to this motor:
http://www.youtube.com/watch?v=QFJ_sueMDRQ
