Want fog lights to work on high beam
Old 12-27-2012 | 07:39 AM
JK-Ford's Avatar
Originally Posted by joe002
You have to set the Jeep up for export (here's the sequence that I was told, but I've never been able to try it):
starscan main menu > vehicle preparation > enable fog lamp output > disable > next/finish > enable >export > next/finish
or
starscan main menu > ECU view > FCM/CGW > misc. functions > enable front fog lamp output > start > next > disable > next > cancel > start > next > enable > next > export > next > finish.
After that, all your digital stuff reads out in "Euro Standard" also. What temperature is 23*C ? How many kilometers is it till your next oil change?
Old 12-27-2012 | 02:37 PM
TexasReaper's Avatar
Didn't think would be such a PITA!!!
Old 12-27-2012 | 05:59 PM
JK-Ford's Avatar
Welcome to the new Jeep Wrangler.
Old 12-28-2012 | 07:55 PM
JeeP_MarK's Avatar
I read se were that this option was going to be available on the next gen procal from AEV , not sure if it's out yet
Old 12-28-2012 | 08:53 PM
joe002's Avatar
If they do that I hope they also add the setting to make it so your headlights don't come on when you unlock the Jeep. There's supposedly a StarScan setting for that too, but I haven't been able to get the dealer to do it. If they add both of those options I'll buy a new ProCal just for those two things.
Old 12-28-2012 | 08:56 PM
GoRemote's Avatar
If I am not mistaken, you can change that in the menu using the buttons on the steering wheel. At least I think it's so on my 2013.... Anyone know for sure?
Old 12-28-2012 | 09:16 PM
joe002's Avatar
Unfortunately it isn't user settable in the 2008.
Old 12-29-2012 | 03:38 AM
JK-Ford's Avatar
I would think that would be based on changes in the regulations.
Old 12-29-2012 | 07:24 AM
joe002's Avatar
Maybe... When did they say it was OK to set your tire pressure indicator to zero so it's inoperable? I'm sure all they need is a good disclaimer, like: "Only to be used in off-road situations. Never use fog lights and high beams when driving on a highway. Please check your local laws."
Old 12-29-2012 | 09:18 AM
JK-Ford's Avatar
So the disclaimer might say: "Beware, Driving with Fogs and High Beams is Bad For Your Wallet"? Disclaimers dont cover issues that are against the law. It isn't illegal to run on flat tires.
