Using Nav-TV Allgig, setting up rear view camera
I'm looking for some help with my allgig (similar to lockpic) to set up a rear view camera. Everything seems in place but the camera just will not light up. I am using a 3.5mm RCA jack from the camera to the "cam in" input on the allgig....and when i put jeep in reverese the screen says "check surroundings" but camera never lights up. I used wire snaps (what i call them anyways) where power wire from camera goes into one side, power wire (white/green from jeep going into lower light) is snapped on the other side and they should be spliced. i did the same with the ground wire. I feel like at this point the camera should light up. Does anyone have any ideas as to what i'm doing wrong?
i've heard some people doing camera power to the back of the nav screen but I don't see the benefit in that since my camera came with a lot of wire to work with. i'd be willing to change my set up if anyone knows what i'm doing wrong.
Thanks in advance!
Thanks in advance!
I'm not sure where you is going wrong but I tapped into the power wire going to my reverse lights so that the camera is powered whenever I shift to reverse.
Thanks in advance!
Thanks in advance!
backup cam help
I'm thorougjly confused and it sucks taking everything apart again to try another method just to have no camera working. Can you also tell me the wire colors you use?
Do you mind telling me where all your connections are and what you used to tap into the wires? I really am frustrated and nav-tv has been of extremely little help. And instructions are very bad. I don't know if I'm supposed to use the camera RCA to the av harness "cam in' or plug into the actual harness with allgig called "backup cam" then use a video out from allgig harness to av harness "cam in'?
