USDM JKs have headlight levelling system?
Just wanted to ask you guys if your USDM JKs have a headlight levelling system? My 2013 JK CRDI has one and the reason im concerned is because I would like to upgrade to trucklite LEDs and was wondering what would happen to this feature of mine. Thanks!
Your feature should stay, if you pull off your grill there should be a small motor on the plastic frame that holds the 7" round light housing that will adjust your headlight level. Just wish we had that feature here in North America!
Damn. Did not know this was an option on JK's. Had it on previous cars, and its really helpful.
It should work with any headlight upgrade, as long as you change the reflector and lens only, with something same size..
