Under Dash Lights
Under Dash Lights
Hey,
I've been doing a bit of investigation on under dash lights. I have a 2013 that comes with the lights stock but I don't like the colour and cannot change them since they are a sealed LED. I've replaced the rest of the interior lights with LEDs to the 6000k colour and would like to add LED strips under the dash and use the wiring for the existing lights. When I looked under the dash at the harness I noticed that beside each of the lights on either side of the jeep is a box that is labeled "LHD". What is this box and what does it do? The plug going into it has 4 wires I believe. 2 power the light and I'm assuming the other 2 power whatever the box does? Would I be ok the cut the 2 wires that feed the light to supply the LED strips, and leave the other 2 wires to plug into the connector?
Thanks
Brent
Thanks
Brent
Hey,
Attachment 399699
Attachment 399700
Thanks
Brent
Attachment 399699
Attachment 399700
Thanks
Brent
Just a suggestion. I used the prewired single LED bulbs on my center stack. Just drill the holes to the correct size so that the bulbs just fit. I just installed three under the ledge that overhangs the A/C controls. A little dab of silicone will hold them in. Then you have excillent indirect lighting that looks custom.
IDK what that box is. If your sure that you are tapping into lighting circuits, then I guess that it really does'nt matter where you tap in at. There is a thread floating around here somewhere that describes how to tap the wiring behind the A/C controls for this very same purpose. Be very careful around the control wiring though. You don't want to tap into a CanBuss circuit.
2013 has footwell lights? nice.
I'm about to start a project installing RGB l.e.d. tape with a controller to adjust the color. Probably going to just wire it to a switch, although I've been thinking about using a double throw switch to turn them on manually or wire them to come on when the interior light is on.
This helps, but leaves more mystery...
Hey,
Attachment 399699
Attachment 399700
Thanks
Brent
Attachment 399699
Attachment 399700
Thanks
Brent
https://youtu.be/zB8jxRntEoA
