Uconnect HELP
Uconnect HELP
Hey folks, so when i bought u saraha i didnt have you connect but i have the chance to buy everything with steering wheel controls. My question is can i plug it all in and use it?
1) What radio do you have?
2) Does the radio have the Uconnect buttons?
3) What all is included in the kit that you're looking at?
4) Depending on the radio, after the install you'll need to get the vehicle flashed for sales code RSP.
The numbers are RH8 and i dont have pictures all the components are still in the jeep being parted out
You'll want to make sure that you get the:
1) radio
2) Uconnect main module
3) mic from the drivers "A" pillar and the lead cable from the module to the mic
4) Integrating harness pigtail between the radio and the Uconnect module
5 Sat radio ant and lead cable that goes to the radio
6) steering wheel control plate
Then remember that after you install everything that you'll need to go to the dealer and have the vehicle programmed for sales code "RSP".
1) radio
