U Connect iphone cable install
Hey all
I did a search for this, but did not find anything. I am wondering how to get the uconnect radio out in the safest way possible to avoid any damage. How can i do this the easiest way?
Do i need special tools?
It is really very easy, no special tools required, go to..
http://www.coastaletech.com/LOCKPICK_MAIN.htm
they have a video on the JK , shows how to remove radio.
Ok
Maybe i missed it but i do not see how to remove the top part of the dash? It says something about clips on a daystar but when i went out to look im not seeing how to get it off....
Ideas?
Ideas?
Use any type of small pry tool you have. Frankly I just use a quarter. Go to the corner (side close to the windshield obviously), stick it down and pop up one side and then do the other. Very simple.
You can get a cheap set of panel tools from Harbor Freight for like $5. They're made of plastic so they won't scratch the buttery plastic of the dash. If that's not an open, try a hard plastic spatula.
