Turning fog lights on with lo/hi beams??
Well looks like I will be working on the running lights relay. I prefer not to do a programmer/chip yet, due to the warranty issues and pricing, not to mention I dont have a clue which one/what to do.
Yep has to be the side marker. Then if you want to do more you can activate another relay using the 12 volts used to power your fog lights from the factory to turn on a light bar or other accessory type lights. Doing this will allow you to use the factory fog light switch to turn them on.
Oh yeah, you just plug it into the OBDCII port under the dash when you need to use it.
