turn signals completely stopped working
They worked just fine the night before but when I drove to work they didn't work. Hazards still work and they also flash when I lock and unlock vehicle any ideas or what could be wrong.
There is no flasher in the JK. It's all computer controlled inside the TIPM. With that in mind, disconnect the battery negative cable for a few minutes. Hook it back up and see if it reset something in the computer.
Your hazards work, so the entire circuit from the bulb to the TIPM is good.
One possibility is a bad control stalk on the left of the steering wheel.
