Turn Signal
Turn Signal
Does anybody know where i can get green turn signal lenses? neon green preferably, to match the halos im going to put into my jeep. Im going to change the turn signals under my main headlights. I wont have my fender flares much longer so i dont care about those so much.
Also any Illinois or Wisconsin Jeepers have any idea of the turn indicator laws?
An officer could write you a citation for anything other than yellow/amber, depending on how he wanted to interpret the law.
**** ****(625 ILCS 5/12-208) (from Ch. 95 1/2, par. 12-208)
****Sec. 12-208. Signal lamps and signal devices.
****(a) Every vehicle other than an antique vehicle displaying an antique plate or an expanded-use antique vehicle displaying expanded-use antique vehicle plates operated in this State shall be equipped with a stop lamp or lamps on the rear of the vehicle which shall display a red or amber light visible from a distance of not less than 500 feet to the rear in normal sunlight and which shall be actuated upon application of the service (foot) brake, and which may but need not be incorporated with other rear lamps. During times when lighted lamps are not required, an antique vehicle or an expanded-use antique vehicle may be equipped with a stop lamp or lamps on the rear of such vehicle of the same type originally installed by the manufacturer as original equipment and in working order. However, at all other times, except as provided in subsection (a-1), such antique vehicle or expanded-use antique vehicle must be equipped with stop lamps meeting the requirements of Section 12-208 of this Act.
****(a-1) An antique vehicle or an expanded-use antique vehicle, including an antique motorcycle, may display a blue light or lights of up to one inch in diameter as part of the vehicle's rear stop lamp or lamps.
****(b) Every motor vehicle other than an antique vehicle displaying an antique plate or an expanded-use antique vehicle displaying expanded-use antique vehicle plates shall be equipped with an electric turn signal device which shall indicate the intention of the driver to turn to the right or to the left in the form of flashing lights located at and showing to the front and rear of the vehicle on the side of the vehicle toward which the turn is to be made. The lamps showing to the front shall be mounted on the same level and as widely spaced laterally as practicable and, when signaling, shall emit a white or amber light, or any shade of light between white and amber. The lamps showing to the rear shall be mounted on the same level and as widely spaced laterally as practicable and, when signaling, shall emit a red or amber light. An antique vehicle or expanded-use antique vehicle shall be equipped with a turn signal device of the same type originally installed by the manufacturer as original equipment and in working order.
