Truck Lite LED Headlight install question
#31
Sometimes you jut have to wait a bit for an answer
...Now if someone that has the rally lights wiring kit wants to give very detailed info on the kit I could make them for much cheaper than rally lights are. Once I have the time I was planning on sourcing all the parts and doing the research anyways. It helps to be a mechanic...
LINK->Daniel Stern Lighting Consultancy and Supply
The flicker I have read is not all that bad, and mostly just there when idling. There are a few Youtube videos that show it. The full harness is a bit overkill for the low voltage truckLites, but very worth it for halogens. From reading way too many lighting threads it seems that all that is really needed is a pigtail (small wire that converts H13 plug to H4) with a capacitor to make the current more smooth.
http://www.youtube.com/watch?v=XQqDt_aE_uI http://www.youtube.com/watch?v=046e5ktYUaM
