Truck Lite Issue
These are all possibilities. But explain to me why tugging on the harness or tapping on the housing stops it? We are not talking about flicker either, the light is cutting all the way out and almost looks like a strobe light.
For your specific issue; its a short. something, somewhere, is loose, broken, bent, and causing an arc. Your anti-flicker harness may be the issue, or it may be internally in the headlight.
And the only other things I have in the Jeep are an aftermarket radio, and the remote start which the constant power is wired off off 8 gauge power wire directly coming from the battery.
[QUOTE=ahfunaki;3777293
The only things that are on this circuit are the headlights. I have nothing else hooked up to them.
And the only other things I have in the Jeep are an aftermarket radio, and the remote start which the constant power is wired off off 8 gauge power wire directly coming from the battery.[/QUOTE]
Is the remote start hooked into the lighting system at all? maybe a vampire tap in a lead?
Pull the fuse for the RECENTLY added remote start are see if it affects the lights in any way. If the problem goes away then you have your answer. Maybe when they put it in the tagged off the wire for some reason? to activate lights? Maybe that is the issue.
And I actually did the install myself ( it's what I do for a living ) so I know that the headlights weren't tapped into at all.
