Trailer break Controler
Has someone instaled a trailer break controler and if you did where did you put it. I am installing a seven pin plug from the stealer ship and would like to know where to install the controler. Thanks for the help
let's just say that the options are very limited if your controller can only be set within a specific range of angles as some do. i have a reese controller and it allows for being mounted at any angle under the sun. that being said i mounted mine to the right of the steering wheel kind of high between the steering column and the center console that way it is easily reachable and i'm not knocking my shins on it since i am tall. i will try to get some pics and post them later.
Ditto.
Get one that can be mounted at any angle. Mine is mounted right below the steering wheel, in between my knees. At first I thought I'd knock it with my knees all the time, but haven't hit it once.
I got the Tekonsha Prodigy. Very happy with it.
Good luck.
Good luck.
