traction control light
So I disables the ESP because I have the jeep lifted 5". The ESP bypass light has went away but the traction control light, jeep with the squiggly lines, is still on. IS this light supposed to be lit if the ESP is disabled?
Thank you sir. I have the same flip kit as you sir. Everything was fine for three days after installing the flip kit and 35's but then driving home one day during a strong cross wind activated the ESP bypass and now I cannot get it to reset. Hence I just fully diabled it until I can figure out why the ESP won't reset itself.
Get the steering wheel straight, if it is, hook a scanner up and check your wheel sensors, o rjust crawl underneath and see if you can find something obvious wrong with them.
