Throttle Position Sensor / Accelerator Position Sensor
I've been having an intermittent DTC for some time (P2138). In fact, there's another thread on here somewhere about it. Anyway, the issue went away for quite some time (several years), and had reappeared for some reason.
2010 JKU Rubicon
There appears to be numerous ideas about the problem, with suggestions on making the DTC go away for good:
- Replace the Throttle Position Sensor (which, basically, means replacing the throttle body)
- Replace the Accelerator Position Sensor (the accelerator pedal)
- Do both
- Replace the connectors for both devices
Right now, I'm inclined to replacing both the Throttle Body and the Accelerator Pedal, and both connectors (the connectors are going to be the difficult task), however I remember reading that if those devices (throttle body and accelerator pedal) are replaced, a visit to the dealer is in the future so that the vehicle can "re-learn" the device parameters. Can anyone verify this? I'd assume that post replacement, the Jeep would automatically go into "limp mode", which might get me to a dealer.
Any help, suggestions would be greatly appreciated.
2010 JKU Rubicon
- Do both
You can disconnect the battery first, follow the wiring diagrams through by simply unplugging at pedal and TB then ring them through with ohm meter with audible ringer to indicate continuity. You won't hurt anything. No need for power. Just make sure it is all plugged back in before reconnecting battery. If there is a problem then you have to go to the middle harness connections to isolate any issue.
