those of you with hid fog lights
Yep. What he said.
Just get the H13 version. Pull out the factory bulbs. Connect the Jeep plug to the input of the ballast. Connect the output of the Ballast/Igniter. My igniter was seperate. Connect the two wires to the bulb. The bulb connections are polarized so it is impossible to cross them.
Including time to zip tie the ballast to the frame, it took me 30 minutes.
Yep. What he said.
How are you attaching the digital ballast to the frame? My ballasts came with mounting tabs with holes so I ended up just using self tapping screws and drilling them into the inside of the bumper. I'm thinking about sandwiching some double sided foam tape between the bumper and the ballast to reduce vibrations. Whadya guys think? The light these put out is amazing!
For now mine are being hled on with two zip ties. When I change the bumper I will fab something up. I though about the double sided tape but a lot of water can get splashed up there just driving in rain.
I like mine even though I used the factory reflectors. The change in output was drastic.
