Third Brake Light (CHMSL) Not Working
Old 05-28-2015, 11:06 AM
ezndo's Avatar
Default Third Brake Light (CHMSL) Not Working
My chmsl stopped working, but both brake lights work, turn signals, etc. Decided to replace the entire chmsl with a spare tire center cap LED from Hyline offroad. Cut the OEM chmsl connector and connected the Hyline LED and it doesn't work either. Ideas? Is there a separate fuse controlling just the chmsl that may be bad. I've searched for answers and came up empty. Thanks for any help.
Old 05-28-2015, 12:57 PM
evoviii2jk's Avatar
There is a separate fuse under the hood if i remember correctly. Not sure which one it is though. I was popping them left and right for a bit
Old 05-28-2015, 01:15 PM
14Sport's Avatar
M1 I think.
Old 05-28-2015, 03:02 PM
ezndo's Avatar
I'll check that first tomorrow am, thanks!
Old 05-28-2015, 03:25 PM
ronjenx's Avatar
Yes, M1 is for the CHMSL.
If M1 is blown, the regular brake lights will still work when the ignition switch ON.
If M1 is blown, the regular brake lights will not work when the ignition switch OFF.
A bad brake pedal switch, (bad, loose mounting, out of adjustment), can cause the same symptoms.
A while back, someone had a non-illuminating CHMSL and it was a loose splice somewhere between the switch and the CHMSL.
Old 05-28-2015, 04:10 PM
14Sport's Avatar
Well there ya go, ezndo, makes it a lot easier. Glad you chimed in, Ron. Your knowledge never ceases to amaze me.
Old 05-28-2015, 04:34 PM
ezndo's Avatar
With this info, I couldn't wait till the am.
So I pulled M1 fuse, it looked OK, and swapped in a verified working 15A fuse.
Still no brake lights or chmsl when brake pedal depressed and engine off. Note I did not start Jeep as I'm changing the oil and letting it drain overnight.
Have not checked the brake switch, I'll check that too.
Thanks again everyone for the help. Ron I've followed your info in the past so I know its' good info.
Old 06-05-2015, 04:37 AM
ezndo's Avatar
So finally problem solved..........there was a short in one of the wires located under the fusebox. Fixed that, then was able to complete my third brake light relocation to the spare. Thanks everyone for the help!
Name:	JK Brakelight.jpg
Old 03-02-2020, 12:55 PM
Craig Cochran's Avatar
Default Tipm box
Hi, so I think it’s my tipm box, I have tried swapping out fuses, hooking a voltage meter up and had electrical engineers at work helping me, but I was trying to wire a reverse camera in, and was going to use the CHMSL light for power since you have to press the break in to reverse so I thought it’d work, well I think I blew something because every Light but the CHMSL works.
Quick Reply: Third Brake Light (CHMSL) Not Working
