Third Brake Light Blocks Camera Placement
I've got a 2018 JKU and the 3rd brake light is just above center on my spare. I don't currently have the bracket to reposition it over the spare, and I want to install a back-up camera right above where the light is now. What are my options? Where can I buy an OEM style bracket and would I need to buy a new light too?
Trying to avoid:
spending $500 on the alpine 2-in-1
an off center camera of license plate
a low camera mounted on bumper/hitch
Trying to avoid:
Do you have a picture of how the camera mounts up? Looking at how/where that light attaches seems like it would be easy to fabricate a little bracket that just rises up allowing you to mount the camera right on top of the light. Excuse the crude edited picture, but just thinking simple flatstock with a 90° bend that gets sandwiched between the brake light bracket and that lug extension -
It seems there could be some solution without moving the brake light. Another option, which I'm not sure would fly with your state requirements for a 3rd brake light would be to lower the light to the bottom lug of the wheel (drill a new hole in the bracket and mount it with a single lug support so it is centered). That might not be high enough to satisfy your 3rd brake light laws though.
When I installed my TypeS license plate frame camera I used the GP Factor license plate relocate kit. It includes mounting holes for the brake light. I haven't moved mine but I will if I get larger tires.
Not sure about the US but up here that brake light does not meet Transport Canada specs where it has been moved to as it is supposed to be at average following drivers eyesight centerline. It was designed to alert following drivers the lead was applying brakes and alert them better. I would simply turf the light and mount your camera.
I'd imagine that California is a lot more strict in its laws.
And to what end those lights function as really baffles me. A supercar that is 40 odd inches high has a light at around 37" so why can't the Jeep taillights work at that height? It's like the video that I just saw from a guy called Jailbreak Overlander who did a wonderful video Telluride to Ouray and he said that the only deaths and injuries was from people not "paying attention" on that pass. We all need to do the same driving and we wouldn't need these stupid lights. But up here in Canada we don't get pollution or safety inspected unless there is an order to do so by police ticket or similar so we get away with more things.
Too bad I can't find a JL style cam that comes out the middle of the rim.
I wonder if you simply flipped the current brake light and bracket upside down if that would open up more of a view for the camera. I do see how mounting the camera on a fabricated bracket like I was originally thinking would be a little unsightly and not very discreet vs hiding in the wheel like this -
Hmm you're right maybe that would give enough clearance.
Also playing with maybe just getting one of these and attaching it to the underside of the brake light https://amzn.to/3rMX10x
Hi! My name is Azariy and I am a new member at your forum! Learning how to post now.
Trying to avoid:
employee monitoring
Trying to avoid:
employee monitoring
