switches
switches
does anyone know if you can buy switches that fit into the factory blanks? I have a 2011 and am adding some lights id love to be able to add a switch into one of the blanks that are located the shifter, where the 4 ways are. Anyone?
thanks
thanks
if you pull that apart you will see a circuit board behind all the switches so it's going to be hard to get any aftermarket stuff in there.
Daystar just put out a switch panel that replaces the net in front of your shifter. That is the route i'm looking at going towards.
The part number is kj71034bk
Really easy to use the switch panel by Daystar super easy to install would recomend.
Attachment 269082Attachment 269083
