Switched 12 volt source
Im looking for a switched 12 volt source to install my led footwell lighting. I know about the ones that runs to the dome light and the one that is on the dimmer switch with the gauges but I'm looking for one that is always 12v when the vehicle is started. Anyone know of any? Thanks!
maybe my write up can help.
https://www.jk-forum.com/forums/show...-Well-Lighting
i used the left 12V outlet which is ignition hot while the right 12V outlet is always on with the battery.
Don't use it for more powerful needs, I tapped and used it as a switched source for 100w windshield lights, found out that the lights pulled too much draw and the JK canbus shut down power to cig lighter.
Does anyone know how to get to the cig lighter on an '11? I followed the write up but the '11 dash is different... Are there any switched sources in the footwells that anyone knows about?
I did the same footwell light addition but wired it into the dome circuit. Anytime you open the door, or turn on the dome, the footwell lights up, works great. Just find and tap into the correct wire in the bundle on the passenger side kick panel. There's a long thread on this topic with the correct wire color (yellow/white if memory serves).
Give this a try: https://www.jk-forum.com/forums/show...d-Power-Source
Or this: https://www.jk-forum.com/forums/show...y-Power-Source
I installed LEDs with the cigarette lighter as power on my 2011. Works great. In order to get to the lighter you need to pull apart the dash. Remove the plastic cover under the steering wheel, unscrew the 2 upper screws that hold in the dash panel. Another screw is under the tray on top of the dash and another is behind the cover where the power window switches would go (i do not have power windows, so that area was blank). Pull out the dash panel. Then you can remove the panel with the AC controls and the one with the cargo net next to the floor. They are just held in with clips. Use a putty knife to get started. The back of the cigarette lighter is right there and the wires are easily accessable to tap into. Quadratec sells a kit but that is probably unnecessary. Then you can run the wires down behind the panels and over to the footwells for a really clean install. I also use that source to charge my iphone while I am driving. Works great all at the same time. I even plug in my bluetooth speaker to the cigarette lighter simultaneously. Even with all that, no problems. i did it all in about 3 hours and I am not swift at these things so I am sure anyone can do it. Good luck.
