Switchback LED question
I'm looking to install something like this on my 2012 JKU:
https://www.youtube.com/watch?v=7dK98Z6Oq_I The poster installed Diode Dynamics SMD60 LED Switchback Front Turn Signals - which have since been discontinue and no replacement model is offered. I won't link to the original topic because it's on another forum but I'm wondering how I could still accomplish this.
I have no clue what I'm doing but it looks like regular amber LED front turn signals for Wranglers are LED SMD27. Could I look for either SMD27 or SMD60 LED Switchback turn signals, with a resistor kit, and install them? On eBay I found a few items under 60 SMD or 27 SMD for LED Switchbacks but it says they won't fit my 2012 JKU.
Link -Notice the AW vs AO.
The AO flashes amber-off-amber.
The AW flashes amber-white-amber.
I prefer the AO, and am not sure if the AW is legal in all countries.
Here you'll find #3157 (the right socket number) White-Amber Switchback LEDs for the '12JK:
Check the - "3157 Selection and Installation Tips", at --
Those are LEDs, so the higher wattage doesn't pose a problem.
I know that the 92 LEDs is used by a few people.
In case the fuse blows, just put a stronger one.
I suggest you take your current bulb out and measure the diameter and length, then pick LEDs that aren't too wide to fit though that hole.
I think it's about 21mm hole, not sure.
The Jeep computer "expects" a regular bulb with higher resistance, and would interpret the low load of the LED as a problem.
To cure that, a resistor is added to each light. See 'Load Equalizers / Resistors', at: One for each light, rated at around the wattage of the LED.
The resistors get warm, so tuck them in the bumper, not touching plastic.
If you put them on the '-' wire (earth, connected to the Jeep body), there's no risk for a short.
I hope this helps.
