switchable power source for a 2007 JK 4 door unlimited
I am adding accessory driving lamps (PIAA) and I need to find a switchable power source under my dash to tie in the light switch to. What color and location can I find this? Please post pics if you have them to help. Thank you.
I believe most people are pulling power from one of the accessory outlets, either the right side= constant power or the left side= power when the key is on. not sure of the wire color but it should be easy becuase there are only two wire on each plug.
Here is a way to get switched power. You can have power only when the engine is running, or power with the engine running, and when the key is in accessory. In my opinion, it's better than using the snap splices.
https://www.jk-forum.com/forums/jk-e...source-191552/
