Superwinch running backwards?
Old 08-18-2008 | 04:56 AM
bahadden's Avatar
i have to agree you have it spooled backwards.
Old 08-18-2008 | 08:19 AM
easttnruby's Avatar
Is there a strength reason for having it feed from the bottom as opposed to the top?
Old 08-18-2008 | 10:22 AM
robin's Avatar
Originally Posted by muddpuppy01
Flip the wires on the battery
you're kidding right?. if not, please don't do this.
Old 08-18-2008 | 04:30 PM
sixt7gt350's Avatar
Originally Posted by .:eMETAL:.
good call sixt7gt350. you beat me to it!
I'm generally known as an a$$, but usually a useful one, so they keep me around.
Old 08-18-2008 | 04:34 PM
scbesse's Avatar
Spooled backwards i bet thats it good call DO NOT REVERSE THE CABLES AT THE BATTERY not a good idea for the winch
Old 08-18-2008 | 05:02 PM
johnnyd's Avatar
The picture appears as the rope is coming off the top, on my SuperWinch the rope is coming off the bottom. Me thinks the rope is spooled on backwards...
Originally Posted by RubiRascal
The EPI has an intagrated solenoid, the wiring terminals are covered by the rubber boots, any idea which ones to swap?
Old 08-18-2008 | 05:13 PM
RubiRascal's Avatar
You are correct, it was spooled backwards. Unspooled it an fed it from the bottom and all is good! Total rookie here, so thanks for all the help! I should at least get credit for a damn fine picture!
Old 08-18-2008 | 05:16 PM
Rhino64's Avatar
Most DC motors will run in either direction buy changing the plus to the negative it will change the polarity of the motor causing it too run in the opposite direction . That what the hand control does.
Quick Reply: Superwinch running backwards?
