Sunpie LED Headlights & Fog Light Install Question
Ok, I did a search thru the lights sections but nothing pertained my question. Recently purchased and installed the 7" SUNPIE LED headlights & 4" fog lights. Everything worked as advertised EXCEPT the fog lights. The fog lights came with the following plug. However; the jeep factory plug and the fog light plug fit perfectly, but they don't work. Am I supposed to use the supplied harness below and tap into my factory harness? Seems kind of silly to do that, but not sure where or who to turn to now. I emailed the company, but no reply yet. Just hoping someone may have had the same situation and can help me out sooner than the company. Thanks.
Issue resolved!
UPDATE on thread; the plugs (pictured) provided apparently are to tie into the factory harness if your Jeep's factory plug will not simply "Plug & Play". Mine were plug and play; however the fog light plug is universal and can be flipped over for the pins to line up correctly. When I looked at it closer, I was able to turn factory harness plug over and then plug it back into the fog light. All works now. I would think this would be something they put in the installation manual, but apparently they want you to figure this out on your own.
Basshole (05-06-2024)
