Subwoofer install, pic heavy...
Didn't realize I had replies in here this year. Well thanks and here is an update. It is still going strong. One advantage that I have found is that a few times I have had water on it and let me tell you the line x seals it well. Water is bad on mdf and there is none getting to it with is setup. It still sounds good although it could be better with a better head unit. Using a loc is not the optimal way to get your signal. My CD player on the stock head unit quit on me so it may be time to upgrade. The pics are there if you want to copy it. Really all you need to do this project is a good miter saw, router to round the edges, hand drill, screws, some bondo, and wood glue. Just ask and I can help with any other questions on a build.
