Subwoofer help
#41
There's an app for that... JL and Rockford-Fosgate have apps for iphone/pod that are pretty close when compared to actual meters... For SPL levels I mean...
#43
I read further and saw you decided not to go with l7 15" just keep in mind you can get a pioneer/pyle set-up and have it sound better than some of the mid-higher level set ups. Its really all about how well you wire it, im sure you know this and im just spewing
its do able for sure! Im excited to see your final product!
#46
If they are both inverted wire them up the same way as now. If one is inverted and sharing the same chamber you swap pos to neg and neg to pos on the speaker inputs. At the sub that is Not the amp
#49
Box is built. Ill be carpeting it tomorrow and sealing all edges. Then next day is wiring amp n subs and feel the bass.
the boot ring on side is where ill be installing a super thick lock the the roll bar. Security purpose
