Sub 2 door jk
Old 07-28-2012, 10:48 AM
Fyrefighter's Avatar
Default Sub 2 door jk
Im looking to what people got in there 2 doors. Cause I'm not sure if I can fit a single 15" kicker l7 or 2 12" any info and pics would be greatly appreciated
Old 07-28-2012, 11:02 AM
treid's Avatar
Had to take out my sub's, No room for gear. But I did have two 10"s could have gone bigger but had good bass with those
Old 07-28-2012, 11:16 AM
I def know I can fit 2 10. But that's what I had in my last car. I want bigger and louder. I'm just curious to if any1 out there has a 15 or 2 12 already in so I can see how there box is
Old 07-28-2012, 11:41 AM
Xman4602's Avatar
Here is mine. It's a 10" kicker. The 600watt ammonia mounted on the reverse side of the enclosure.
Old 07-28-2012, 12:04 PM
Blakspire's Avatar
JL Audio builds a stealthbox for the 2 door, with a single ten in it. That would be a viable option.
Old 07-28-2012, 12:19 PM
ZMagic97's Avatar
Same. Had this in my JK, but wanted the room for camping and wheeling. Didn't make sense for me to keep it in there.
ID:	346669   Click image for larger version
Old 07-28-2012, 12:22 PM
Thats in a 2 door?
Old 07-28-2012, 12:30 PM
ZMagic97's Avatar
Originally Posted by Fyrefighter
Thats in a 2 door?
Yup, took it out several months ago with my back seat. Planning on making a carpet covered sub box with will ratchet to the floor with electrical plugs so it can be taken out or installed very quickly. Box was built for the display at SEMA.
Old 07-28-2012, 12:50 PM
So do you think I would be able to build a custom box to fit a 15 l7 in the 2 door without removing seat
Old 07-28-2012, 01:05 PM
ZMagic97's Avatar
I would say yes. My box was built with the subs down firing right behind the seat. There was about a 3" gap from the bottom of the box to the floor (not shown in the front of the box) and is slanted as it goes up behind the seat. It was made so the back of the seat and box had about 1/2" of space between them. It houses 2 10" JL V3W3s. It's a bit of a tight fit, just have to measure twice cut once and do a lot of fitting before sealing the box.
Quick Reply: Sub 2 door jk
