stubby antenna ???
w w w.shortyantennasource.com/store/index.php?main_page=index&cPath=5_80&zenid=guigktn ko7s9j63sbcl1ttlun0
here's what I've got. I got the 8 inch one.
Reception is a little worse, but I live in a bigger city not far from the stations I listen to so it's not bad at all.
Here's a related thread (includes suggestion on cutting the stock antenna) ...
Shorty Antenna Install Write-up
You can get one at your local auto parts store if you have access to a 5/16 tap. Look for the one that has female threads on the bottom. The one I bought came with a bunch of adapter studs ( that were useless ). As I mentioned, tap out the bottom of the antenna to 5/16" threads. Get a 5/16 bolt and cut off the hex head. Cut the threads to the proper length.
There you go
There you go
