Strange rear turn signal problem
Bulbs are fine but what j33p4life posted makes perfect sense...I pulled each contact on the bulb using needle nose pliers - easy to do...I'll let you know how long it works
Just wondering if bending the connectors worked? Just got my replacement bulbs and my system still blinks at a rapid pace also it stops working after a few minutes of driving
I was hoping someone had an answer to a similar problem. I have a 2007 jk 4dr. The left turn signal is intermittant. When ever I start out it works, then about 10 to 15 minutes later it quits working.
I have replaced the bulb, cleaned the contacts, bent the contacts, reset the computer, looked for bad grounds and connectors with no luck. Has anyone else experienced this?
