Stranded versus Solid Cable
Old 04-24-2013, 08:33 AM
JK-Ford's Avatar
Originally Posted by Twinkydog
Stranded cable will have a higher current rating than an equally sized solid cable. This is due to the heat dissapating capability created by the increased surface area of the individual strands. This may or may not have any bearing on your install depending on how close you are to exceeding the current handling capability of the wire you installed.
Solid conductors are not generally accepted for use with DC currents. Well at least not in the currents I'm use to dealing with. DC currents don't travel over long distances very well. And stranded conductors are better suited to help transmit those currents.
If the OP is using a #12 ( or even a #10 ) conductor to carry a 40 Amp load, then he has exceeded the capabilities of those conductors ( solid or stranded ).
Quick Reply: Stranded versus Solid Cable
