Stock tweeter replacements that are easy to install?
Sorry if this is a dumb question but I can't find too much info on it. I'm looking to replace the stock tweeters with ones I don't have to install any crossovers or amps to use - I just want to pop up the stock ones, unplug them, plug in the replacements, and pop them back into the dash. I have a 2012 JKU Sport with stock audio. I'm also trying to spend ~$30.
Also, will these even make a difference over the stock tweeters?
Powerbass S1S 1" Silk Tweeters
I have the ones from quadratec. They are exactly what you are looking for. Super easy install and noticable difference in sound quality. They probably weigh 10X more than the stockers.
I saw those but I don't want to spend $120 on tweeters. I'm trying to replace the stock speakers on a budget so trying to keep it ~$30. Been picking up returned Mopar 77KICK10's for cheap to replace the front and sound bar speakers.
There is a tweeter mod that takes less than a half hour and costs peanuts that is providing some nice results!
Removing the tweeter (if you have the tombstones) is as simple as a slight pry with a flat head.
Gotcha. Every tweeter upgrade I have read about requires trimming the hole in the tombstone with either a dremel or a razor knife. So I don't think you will find ones that are exact fit. But sorry, I still have stockers so can't help with a recommendation.
Thanks that helps thanks it looks like I'll search around for the quadratec ones for cheap.
