Stock Sub Replacement
Anyone replaced the stock sub in a 2007? I just want to replace the sub and/or add a small amp. Anyone know anything that will fit and if the factory amp will power anything other than the factory sub?
Any shallow mount sub will work. Otherwise you will need a spacer ring to accommodate the magnet depth of most decent subs. If you plan on keeping the factory amp, find a sub that doesn't take much power to push it
Think this would work? Anyone does this yet?
Width 8-1/2"
Depth 4-1/2"
Weight 5.2 pounds
Woofer Size 8"
Woofer Material Injection-molded SoloKön
Magnet Size 45 oz.
Continuous Power Handling 100W
Peak Power handling 200W
Impedance 4 ohms
Number of Voice Coils 1
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=417019"/>
Width 8-1/2"
Depth 4-1/2"
Weight 5.2 pounds
Woofer Size 8"
Magnet Size 45 oz.
Impedance 4 ohms
Height 8-1/2"
Width 8-1/2"
Depth 4-7/8"
Weight 6.6 pounds
Woofer Size 8"
Magnet Size 24.2 oz.
Continuous Power Handling 200W
Peak Power handling 400W
Impedance 4 ohms
Number of Voice Coils 2
Efficiency 82.8dB
This is the 4 ohm dual voice coil version
Width 8-1/2"
Depth 4-7/8"
Weight 6.6 pounds
Woofer Size 8"
Impedance 4 ohms
Efficiency 82.8dB
Width 8-1/2"
Depth 4-1/2"
Weight 5.2 pounds
Woofer Size 8"
Magnet Size 45 oz.
Impedance 4 ohms
Attachment 417019
Width 8-1/2"
Depth 4-1/2"
Weight 5.2 pounds
Woofer Size 8"
Magnet Size 45 oz.
Impedance 4 ohms
Attachment 417019
RE audios are hard to beat for the price.
RE Audio 8" Subwoofers | Car Subwoofers | Car Audio | Car Audio, Video & GPS at Sonic Electronix
