Step By Step Installation of Rigid Dually LEDs using BDF Fog Light Bracket
Just ordered a set of Dually spots and with the BDF brackets and Truck-lites from Northridge 4x4.
Plan on just wiring in the Duallys in as fogs with the factory wiring. I thought about using a relay and the factory switch to activate them. I wondered if anyone has tried to mount a switch inside to run them independent or off the factory switch? If so would I just run the factory wire and the new switch wire to the same post on the relay? I'm pretty comfortable with wiring just haven't had much experience with custom wiring involving relays.
Basically I want them to act like the stocks with the switch in one position and turn on independently in the other position. Any input as to what the best way to accomplish this would be appreciated.
