Starting issue
Starting issue
I have a 2007 JKU with automatic transmission. I put a new motor in it, which means that I disconnected the transmission cable at the transmission. After I put everything back together, I get just a click when I try to start the Jeep most of the time. It will start but can take up to 40 or more attempts. There is no set way that makes it start. I can push up on the selector, put it in neutral, run it through the gears ending in park or neutral, foot on the brake or off...it will intermittently start in any of these positions. I have switched all the relays around and it's still the same issue. It also has had 2 brand new starters that didn't help either. Any help is appreciated.
Sent from my SM-N900V using Tapatalk
I've had the click and no start problem every summer with my 2007 for the past three years. I've been through 2 new starters and batteries. Last summer after reading threads I would just push the shifter forward if I had the click and it would start for me. Hope this helps.
There is a park switch sensor in the tranny that is known to go bad. I have the same issue. Just like stated above, push the shifter towards PARK when you get the click and then try to start it again. Works everytime for me...
