Starter connector broke
So the plastic connector that connects to the starter on a 2013 wrangler sport unlimited broke on a friends jeep. We can't find a replacement connector anywhere! Tried the jeep dealer ship, local auto parts stores, online, and can't seem to find anything. Has this happened to anyone else? If so how did you fix it!? Need help!
Have you tried one of the websites that specializes in Mopar connectors? On this one, select the connector type based on the number of pins, then scroll through the pages to see images of each connector they offer ...
MOPAR Wiring Harness Service Connector Manual
If you don't find it there, other websites exist that specialize in connectors and harnesses for Mopar. However, you could be in the position where the connector is only available with an entire wiring harness. In that case, you might check junkyards.
https://www.onlinecomponents.com
connector is only available with an entire wiringharness. In that case, you might check junkyards.
Try online components
user 729872082 (10-31-2022)
Tti
https://www.ttiinc.com/content/ttiin...mber=2098198-5
Above is a link to buy a replacement plug end. Mine broke also where the lock button goes on the plug.
Here was my quick fix
I did this until I can get a new connector shipped in to wire in.
The bulbs have two “wings” on the side. Put some latex gloves on (as usual when dealing with bulbs) and drill a hole in each one of the wings to allow a zip tie through.
Push your bulb in tight and zip it up. Works great as a quick fix.
