Soundbar speaker Wire Help please!
Hey guys, I was wondering about the wires that run up to the sound bar. I am going to box a set of 6x9's under the rear seat, and wanted to tie into the sound bar wiring.
Problem... The speaker wires are a different colour to the ones I identified going up to soundbar from the B pillar................ Any experience to share?
I want the colour of wires that go to the left sound bar speaker, and the colour of the wires that go to the right sound bar speaker please!?
Thanks a bunch!
Paul
Thanks a bunch!
Paul
Man this isn't your dads old f150. I wouldnt go splicing and tapping wires. If you do tap into those you need to make sure the impedence stays the same. those are 2ohm speakers up there. I am not an electronic engineer so hopefully one will chime in here (frank where are you?) but if those 6x9s you bought are 4 ohm, then I would change the soundbar speakers to some 4 ohm ones also. then run each channel in parallel to create a 2 ohm load.
The wires on top are different in colour at the speaker .................. I looked where they were plugged up. The loom that goes up there has different colours, hence the question....
I am not going to use the soundbar speakers for now. The 6x9's are there till I go with an amp and sub. Then It will be a component set up front, 2 way in the soundbar. Right now I want some more sound with the boxed 6x9's.
Thanks
Paul
Thanks
Paul
What are the impedence of the 6x9s? the factory speakers are 2 ohm. I know it is a pain in a rear but it is important to keep impedance the same. From what I know it is like changing resistance across a circuit. You can make things burn up.
