sound system help
sound system help
if i use the stuff in the links below will it work and will it sound good
http://www.ebay.com/itm/2-KICKER-CVR...item45fe73eca6
http://www.ebay.com/itm/NEW-DB-Drive...item2eb8af15fd
http://www.quadratec.com/products/96082_65XX_PG.htm
am i missing anything also thanks in advance
i was wondering if the headunit and amp would have enough watts to work with those subs
well by the looks of it, that amp doesnt seem to have a high level input (which means you plug speaker wires in as its input instead of RCA cables)
to run an amp off of the stock head unit you need a high level in put on the amp, or a high level converter. which converts speaker wires to RCA cables.
