Sound Ordnance B-8PT Install
Old 12-26-2011, 06:28 PM
zippodragon's Avatar
Default fits well
[QUOTE=ac1brooks;2748807]I've mounted mine under my rear seat. I initially put it under the passenger seat, but Sounds much better under the rear seat. All I did was zip tie it to the rear seat brackets & I gave myself a little extra wire so I could easily pull it out & disconnect it if I need to. I also mafe a carpeted box to hide it with when my doors are off
Thanks,
Do you think is worth it?
The wife just got me some Kicker speakers for the roll bar as a X-mas present. I hope to install them some time this week and then order the B-8PT.
Old 12-27-2011, 10:29 PM
81toyota's Avatar
I have mine installed under the front passenger seat. I used speaker level inputs instead of a converter. I've had it installed for about 6 months and it sounds great. Fits perfect under the seat. I don't have it secured and have had no problems with it moving around.
Old 12-28-2011, 08:48 PM
Default looks good
It fits just right. That is what I wantwed to see.
Did you use the rear or front speakers for the inputs?
Any rouble running the powerline thru the firewall?
Old 12-28-2011, 11:50 PM
ac1brooks's Avatar
It definitely gives you that missing bass, however it's not going to rattle your seat loose
Old 12-28-2011, 11:51 PM
ac1brooks's Avatar
I tried this, but it sounded muffled to me. Also I ran a LOC from the front speakers @ ran used rear speaker level inputs to a 150 watt am
Quick Reply: Sound Ordnance B-8PT Install
