Sound Ordnance B-8PT Install
fits well
[QUOTE=ac1brooks;2748807]I've mounted mine under my rear seat. I initially put it under the passenger seat, but Sounds much better under the rear seat. All I did was zip tie it to the rear seat brackets & I gave myself a little extra wire so I could easily pull it out & disconnect it if I need to. I also mafe a carpeted box to hide it with when my doors are off
Thanks,
Do you think is worth it?
The wife just got me some Kicker speakers for the roll bar as a X-mas present. I hope to install them some time this week and then order the B-8PT.
Thanks,
I have mine installed under the front passenger seat. I used speaker level inputs instead of a converter. I've had it installed for about 6 months and it sounds great. Fits perfect under the seat. I don't have it secured and have had no problems with it moving around.
looks good
It fits just right. That is what I wantwed to see.
Did you use the rear or front speakers for the inputs?
Any rouble running the powerline thru the firewall?
