Solar panels
Solar panels
Was reading about someone using solar panels to charge a battery that powered a refrigerator and inverter.. Has anyone else done this and could explain how this works and recommend how I would set it up
Solar panel charge battery/batteries, the battery powers the inverter , the wattage of the inverter should exceed the wattage for the refrigerator. You can YouTube the set ups others have done.
I think someone did a write up of installing a solar power system on their off road trailer a while back. From what I remember, the solar panel powers a solar controller, which charges the battery that powers the the inverter.
https://www.jk-forum.com/forums/jk-e...ations-320150/
Here's what I did.
What are the things you want to power with your solar system?
Here's what I did.
https://www.jk-forum.com/forums/jk-e...ations-320150/ Here's what I did. What are the things you want to power with your solar system?
It's really very simple there are numerous write ups on Expedition Portal.com from the over landing guys. Just a suggestion run your refridge on 12 power as you lose too much conveying 12v to 110ac. For most applications a 100 or 80 watt panel will do. I have a 100 watt panel mounted to the top of my Wilderness rack on a 2012 jk sport and it provides plenty of juice.
Mostly running a refrigerator and charging a cell phone or 2 that we use to play music and also connecting to my roof top tent and run the lights and power outlets I have on there and I'd like my solar panel to connect to my genesis dual battery kit. I don't know if it could possible damage the isolator or how to wire it to charge both battery's or how to wire it at all.. I use my jeep for camping
For charging both batteries I see different options:
1. You connect the charge controller to the main battery. That will first charge the main battery. When the voltage gets to be 13.2V or higher, it'll trigger the isolator and then charge both batteries. This might not work since the charging voltage can be lower than 13.2V.
2. There are solar charge controllers that have ports for two batteries. You can connect the charge controller to both batteries and charge them independently. But I don't know if they charge simultaneously or switch between the batteries.
3. Use 2 charge controllers - one for each battery.
Question is if you really have to charge the main battery...
Former Member
You will get better replies if you can say everything you want to power is 12v dc.
If you plan on taking something out of your house to use in your rooftop tent in the middle of nowhere powered by 110v ac then that is a different question
