Side marker help
Side marker help
I wanna replace the side marker lens on my 2013 jku any one do this already i could use pointers
Sent from my DROID RAZR using Tapatalk 2
I just tinted mine. First disconnect the bulb. It's 1/4 turn . Then there's two clips up underneath to hold the inner fender in place. There's also two rivet style plastic clips in the edge of the fender to remove. Use a small punch an apply pressure to the center to push it through, you will reuse these wen you put back together. Finally remove one clip holding the lens in place and wrestle the lens out from between fender and inner fender.
When you go to reinstall those rivet style clips, I used a small pair of channel locks and pushed the back over the pin and they snapped back in place.
Hope it works for you. There's also something on google I searched and found out the first time I did it as well. YouTube might have something.
Cheers.
Cheers.
