Show me your subwoofers
#42
#44
I'm waiting for my MyGig AV9003 harness to get here, the amp isn't powering anything at the moment and I didn't feel like taping off all the wires, so I just screwed it in and left it. I'm building an amp rack for it while I wait for the mail
#46
Yes, you can. Depends on what you consider "high quality" though. a JL 8" should fit (NOT a w7), most kicker's will fit. Just check the mounting depth and if the sub has a vented pole make sure there is an extra 1" of space behind the sub.
#47
Runit3,
I was thinking of using the dynaudio set up, use them in my theater set up and they are great.
While I wish I could get more than one 8" driver, feel it better to keep the Jeep in stock form.
Michael
#48
I've only heard good things about Dynaudio, their MW172 would be an amazing drop in replacement but the mounting depth looks iffy & 4ohm 150w nominal makes the infinity stock amp choke.
IMO the stock amp is the weak point in the system, you can get a definite gain in quality from drop-in's but I like my bass -This coming from an owner of a Hifonics powered Kicker S15L7- I'm way past my teenage years of blowing up parking garages car alarms, now I like a quality dual 8" set-up with hearing retention.
The stock sub location & mounting system is great, the power you can run to it is limited by the 16/18ga wire & stock amp output.
#50
