Sealed Beams headlamps ???
Does anyone know if Sealed Beams headlamps will fit in the new JK? I have a set of really good Cibie concave headlamps i wanted to use.
Thanks in advance.....
Are you sure they're sealed beam? The kind you can rotate to switch between RHD and LHD?
I think they were originally designed for 45/40 R2 bulbs but you can fit H4 in them.
Just use a harness from Rallylights or Stern; they should fit.
If they really are sealed, I haven't seen them.
