Rugged Ridge wiring harness
I bought the Rugged Ridge wiring harness and I'm not sure how to wire up the switch harness. There are 3 wires ( black, white and red) now the black I figured is the ground and there's a eyelet terminal on it. The white has a slide connector and I assume plugs into the wires from the relay. Now the red wire is just cut on the end, no terminal or connector. So I'm not sure where that goes.
It probably connects to the positive battery terminal.
