Rugged Ridge A Pillar Switch Pod
#81
Yes, my switch configuration has 5 leads. Two of them were connected to ground (upper and lower led grounds), 1 to the orange/ gray wire (lower led, the green led with my switch letters), and the other two went to the lights (I have KCs, so 1 went to the relay- green wire I think- and the other to the white KC wire- i Think it was the 12V fused wire).
#83
#84
Installed my RR A-pillar switch panel today, in my '12 JKUR.
Would agree that the fit is not what I would have hoped; took a lot of pushing and prodding to get the right-side edge lined up to the windshield, only to have a gap on the edge near the door. WIth the door closed, you can't see it, but damn, I know it's there.
But the OTRATTW switches are perfect, and I even managed to wire them correctly, so I'm good to go.
#87
Added a new switch to mine on top of the other 2, since it is above the cutouts, the top switch required that I take out some of the plastic support in the back. Nothing that is going to cause a problem maybe 1 sq in or so near the plastic post index piece that doesn't clamp to anything just goes in to a hole. These switches only require a 7/16th hole to mount making it easier to install. They are rated 30A but are only driving relays in my setup.
