Rugged Ridge A Pillar Switch Pod
Old 06-28-2012, 07:33 AM
  #41
Originally Posted by Dieselguy3
There is 2 different types of drawing on the last link you have posted. One is for a power seeking circuit the other is ground seeking circuit. Which one are you wired up as?
I'm using #1. Sorry, I forgot that had 2 drawings on it. I used the drawing to know which terminals to use for what. I attached my wire from the fuse box to terminal 3 for power, grounded under the steering column with Terminal 5, and Terminal 2 is what is going out to the light. So that's the part that doesn't quite make sense in my head. I'm only putting 1 wire out to the light that has 2 (ground/power) so the only thing I can think of to do is run the power wire to it, then ground the light somewhere in the back where I need it. I'm no electrical guru so that would be why it's not working.
Old 06-28-2012, 09:17 AM
  #42
Dieselguy3's Avatar
Is it only 1 wire going to the light and it's magnetic mounted? If so it uses the magnet as the ground when attached. The ground on the switch is for the light in the switch. Also if you are not running a relay check to make sure the switch will handle the amperage across it. Wire size is the easy way to tell what amperage the light needs.
Old 06-28-2012, 02:12 PM
  #43
The light is magnetic but it originally plugged into the cig lighter and worked when not touching a metal surface.
Old 06-28-2012, 08:58 PM
  #44
Dieselguy3's Avatar
Then it sounds like the ground might be your issue. Please don't take offense to this question but r u sure you have the correct positive wire hooked up to your switch? Also if it was a joined pair of wires where do you have it grounded at?
Old 07-01-2012, 10:35 PM
  #45
Phunkeydude's Avatar
Having some fun with my light switches from OTRATTW. Installed on a 2012 Switch Pod. Next step to wire them up. Dual LED. Wording is in Amber and comes on with ignition, symbols are green and turn on when switch is turned on.
ID:	336286   Click image for larger version
Old 07-01-2012, 10:38 PM
  #46
Couple more photos of install. Rockers had to be sanded down to fit properly.
ID:	336289   Click image for larger version
ID:	336290   Click image for larger version
ID:	336291   Click image for larger version
Old 07-01-2012, 10:46 PM
  #47
mr.wolf's Avatar
Wow great job.... Looks good
Old 07-01-2012, 11:57 PM
  #48
MrCourtney's Avatar
Do you have a quick wiring diagram where you grabbed the "on with ignition"?
Old 07-02-2012, 10:02 AM
  #49
I just used the "12 Volt Power Adapter" wire harness from Q_____tec to tap the aux power that is ignition switched. Then ran wire over to switches for power. The switched come with a wire diagram for the 5 prongs to let you know which prongs are for which LEDs.
Old 07-03-2012, 08:38 AM
  #50
Installed...
ID:	336776   Click image for larger version
Quick Reply: Rugged Ridge A Pillar Switch Pod
