Rock Lights. What are you guys running?
#21
I have a homemade sPod. All I had to do was tie all the lights together, then run 1 power and ground in the cab. Essentially plug and play. The lights have magnets so all you do is stick them where you want. I'm still hesitant on the magnets and will probably put 3M industrial tape eventually...but they haven't moved yet?
#22
Yeah I have an SPOD, so I will end up doing the same as far as wiring goes. Looks great man
Can you show exactly where you mounted them in the wheel wells ?
#28
It's been nasty around here...finally had a chance to snap some pics. I'll take better shots next week when I have it on the hoist changing my bent rear shafts.
Front wheel well
Front cross member, angled towards bumper/ground
Just inside the stock Rubi rails
Rear wheel well. Wire ran into tail light area, then in cab
LoD rear bumper. Used the safety chain mounts & angled towards rear axle
Front wheel well
#30
